Yli.8
Nov 2, 2020 01:24 UTC
UART DMA fifo error
I have a new problem about serial communication. When UART sends and receives data quickly, there will be FIFO error.
This is my code
Christophe Guibout
Nov 25, 2020 13:54 UTC
Hi @昌�?� �?�​ ,
Could you please share more details on your board and the hardware setup, the MMDV version on which you are based on, and if you've made some modifications ?
How did you configured the UART (baudrate), and do you use HW flow ctrl (DSR/DTR, RTS/CTS) ?
Thanks,
BR,
Christophe
