SChen.11
The DK2 board recording voice is very low volume
Hi, I test the record voice on dk2 board. Using below command to recorded. After recorded, I use aplay to play that file. The sounds volume very low. I had setting some volume through alsamixer command.
arecord -f cd -c 2 test.wav
Does it working correct?
Olivier GALLIEN
Hi Steve,
Are you aware and did you refer to wiki page ?
https://wiki.st.com/stm32mpu/wiki/How_to_record_audio
Which input source are you using ?
Thx
Olivier
SChen.11
SChen.11Author
Yes, I refer that wiki page and execute those command to record audio. I use a mobile headset from samsung.
Olivier GALLIEN
Hi @Community member​
Could you please share with us :
- dmesg content after arecord command
- output of execution of alsa-info.sh script attached ( bash alsa-info on the target )
- audio file recorded
Olivier
