Jul 4, 2023 10:59 UTC
Switch uboot logs to usart6
Hello, I have a board based on the stm32mp153a and I'm trying to get it to boot, unfortunately I can only access USART 6 while it seems that uboot only tries to interact using uart4.
In my dbs file I have overridden usart6/status to be "okay" instead of disabled and have set stdout-path in /chosen (though I believe that would only impact the kernel)
However this is not working and I think I am missing something, does anyone know how to change the port used for output by uboot?
Thank you for your help
Olivier GALLIEN
Jul 5, 2023 07:16 UTC
Hi @lorenzoruffati
Can you have  a look to this post Solved: Change default tf-a and u-boot serial linux consol... - STMicroelectronics Community
It may answer or provide good hints.
Olivier
Jul 6, 2023 07:59 UTC
Thank you for the link, I'm checking it out now, however I am also not getting any output from tf-a either, whereas the user in the linked thread could see the output of tf-a
