Ara.1
Jan 5, 2021 19:04 UTC
stm32pm1 power failure
Strange issue
used power supply 24v, 5A
If we connect debug 3.5 MM cable on debug port, then only unit boots up and taking to kernel command line prompt else it does not boot up
I tried taking out LCD display , USB, battery, still above issue there
its a customized board,
help me to diagnose
PatrickF
Jan 11, 2021 16:58 UTC
as it is custom board, we need more information to help you. I think you already done some investigation and results. We could answer only to precise questions on a specific STM32MP1 behavior.
Regards.
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
Ara.1
Ara.1Author
Jan 11, 2021 17:06 UTC
its a junk character received , when physical debug cable,
i bypass this scenario in uboot , now working
