Apr 17, 2025 7:31 AM UTC
STM32MP15X-EVAL power brick replacement
I've lost the power brick for my STM32MP15X-EVAL board. It's a 5v-3a barrel connector, but I don't know the polarity and it's not written on the board or anywhere.
Does anyone know where I can find a replacement, or the exact spec of the power brick so that I can find another one ?
PatrickF
PatrickFBest answer
Apr 18, 2025 12:52 PM UTC
If it helps, the supply I have on my desk is labelled Cincon TRG30R050V-12..., but other suffix might be ok too if plug is still a 5.5 x 2.5mm and at least 9mm long.
https://www.cincon.com/productdownload/TRG30RV-cable-DC-Plug.pdf
Obviously, other supply brand will work if same voltage/current and plug.
Regards.
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
mbarg.1
Senior III
Apr 17, 2025 7:52 AM UTC
As far as I know, evrybody is selling only positive inside, negative outside.
You can pick up any providing 5v +- 0.1V 3A (but 5A gives more room for expansions) is deilvered..
PatrickF
PatrickFBest answer
Regards.
xavAuthor
Apr 18, 2025 1:37 PM UTC
Exactly what I needed. Thanks !
