Dat Tran
Senior II
Dec 22, 2023 20:51 UTC
STM32MP153 - How to enable HSI clock?
Hi, I set MCO1 using HSE clock and get 8MHz working well (my HSE is 8MHz)
But I need 16MHz or higher on MCO1, so I changed to MCO1 source clock by HSI but there is nothing.
I tested other CSI, HSE, ... MCO1 work, except for HSI.
I think there is something or register to enable HSI but don't know where/ what it is
Anyone know how to enable HSI clock?
PatrickF
Jan 3, 2024 11:20 UTC
Hi @Dat Tran
System is booting using HSI, so unless you disabled it, it is enabled by default.
Did you try adding a divider by 4 (MCO1DIV = 3) and updating the MCO1 GPIO OSPEEDR to 0b01  ? Maybe the 64MHz is simply vanished on the output pin because too fast.
Regards.
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
