AVazquez
Nov 7, 2019 10:54 AM UTC
speaker output in STM32MP157C-EV1
HI, All.
I would like use speaker output in STM32MP157C-EV1. I revised the wiki but there aren't references about how play audio with speaker output. Is it enable speaker output to this board? Is it possible enable this output to play audio?
Regards!
Alex.
Bernard PUEL
Bernard PUELBest answer
Nov 12, 2019 1:52 PM UTC
Working alsa config for EV1:
amixer -c 0 cset name='AIF1DAC1 Volume' '96' '96'
amixer -c 0 cset name='DAC1L Mixer AIF1.1 Switch' 'on'
amixer -c 0 cset name='DAC1R Mixer AIF1.1 Switch' 'on'
amixer -c 0 cset name='DAC1 Switch' 'on','on'
amixer -c 0 cset name='DAC1 Volume' '96','96'
amixer -c 0 cset name='SPKL DAC1 Volume' '50' '50'
amixer -c 0 cset name='SPKR DAC1 Volume' '50' '50'
amixer -c 0 cset name='SPKL DAC1 Switch' 'on'
amixer -c 0 cset name='SPKR DAC1 Switch' 'on'
amixer -c 0 cset name='SPKL Output Switch' 'on'
amixer -c 0 cset name='SPKR Output Switch' 'on'
amixer -c 0 cset name='Speaker Mode' 'Class AB'
amixer -c 0 cset name='Speaker Volume' '50' '50'
amixer -c 0 cset name='Speaker Mixer Volume' 3
amixer -c 0 cset name='Speaker Reference' 0
amixer -c 0 cset name='Speaker Switch' 'on'
This use case will be added to wiki:
https://wiki.st.com/stm32mpu/wiki/Soundcard_configuration
PatrickF
Nov 7, 2019 11:03 AM UTC
Speaker is not enabled in our examples deliveries. Need to change some Codec driver configuration.
See https://wiki.st.com/stm32mpu/wiki/Audio_codecs_hardware_components#Wolfson_wm8994
and STM32MP15 evaluation board sound card configuration
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
Bernard PUEL
AVazquez
AVazquezAuthor
Nov 12, 2019 3:19 PM UTC
Hi, Bernard!
Perfect, I've done a quick test and I can now play sound through the speakers.
Thanks!
