Ala
Senior
search a char array within an other char array
hi everyone
I'm trying to search for a certain char array(say char Temp[]) within a lager array in this case, char Rcv[500]. here is my code
int scanRcv(char *Temp){
int ii=0;
for(int i=0;i<RcvLength;i++){
while(Rcv[i]==Temp[ii]){
ii++;
if(ii==strlen(Temp))
return 1;}
else
{return 0;}
ii=0;
but I don't know why it doesn't work and does not return 1, though I think the code works....
I also tried this code too but it didn't work either
if(strstr(Rcv,Temp)!=0)
		return 1;
else
		return 0;
please help
Clearly it doesn't work. You reset the index at every iteration of the inner loop. You exit immediately on the first match/mismatch.
Get the indentation presented more clearly.
Get the logic worked out.
Make some assorted test cases, and show how the function gets used in normal operation, and that it recognizes the strings.
Ala
AlaAuthor
Senior
dear clive1
I just reset the index after I find the entire match (i.e. ii==strlen(Temp)). what's wrong with that?
PatrickF
As strstr() return a pointer, you should test for a null pointer in case string is not found.
e.g. if(strstr(Rcv,Temp)!=NULL) ....
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
