mishuk
Mar 3, 2023 11:57 AM UTC
RPMSG SDB driver allocates buffers in reserved memory
We have been using RPMSG_SDB driver from LogicAnalyzer example. By default, RPMSG_SDB uses common CMA area for allocating buffers via
dma_alloc_coherent()
We want to allocate SDB personal buffers from reserved memory regions. We adapted both device-tree and SDB driver. Device-tree snippet:
reserved-memory {
 shared_buffers: shared_buffers@D2000000 {
	compatible = "shared-dma-pool";
	reg = <0xD2000000 0x400000>;
	no-map;
rpmsg-sdb@0 {
 compatible = "fmx,rpmsg-sdb";
 	memory-region = <&shared_buffers>;
SDB driver compatible string:
static struct rpmsg_device_id rpmsg_driver_sdb_id_table[] = {
	{ .name	= "rpmsg-sdb-channel" },
static struct of_device_id rpmsg_driver_sdb_dt[] = {
 { .name	= "rpmsg-sdb-channel",
 .compatible = "fmx,rpmsg-sdb" },
MODULE_DEVICE_TABLE(rpmsg, rpmsg_driver_sdb_id_table);
static struct rpmsg_driver rpmsg_sdb_rmpsg_drv = {
	.drv.name	= KBUILD_MODNAME,
	.drv.owner	= THIS_MODULE,
	.drv.of_match_table = rpmsg_driver_sdb_dt,
	.id_table	= rpmsg_driver_sdb_id_table,
	.probe		= rpmsg_sdb_drv_probe,
	.callback	= rpmsg_sdb_drv_cb,
	.remove		= rpmsg_sdb_drv_remove,
SDB driver memory allocation inside rpmsg_sdb_drv_init(void):
ret = of_reserved_mem_device_init(rpmsg_sdb_dev);
It fails with error -22 (EINVAL). What might be the culprit ?
