Dec 1, 2023 3:27 PM UTC
Push the devicetree into the board fails
Hi I am using STM32mp157-DK2 for the first time.
I am trying out the section Modify, rebuild and reload the linux kernel which is described in following link
https://wiki.st.com/stm32mpu/wiki/Getting_started/STM32MP1_boards/STM32MP157x-DK2/Develop_on_Arm%C2%AE_Cortex%C2%AE-A7/Modify,_rebuild_and_reload_the_Linux%C2%AE_kernel
I was able to build the Kernel successfully,
but while transferring the files to the board, it fails the below command
scp arch/arm/boot/dts/stm32mp1xx*.dtb root@<board ip address>:/boot
with following result
 stm32mp1xx*.dtb: No such file or directory.
I checked the directory, and did not find any files with stm32mp1xx.
Kindly help me out to resolve this
    Olivier GALLIEN
    Olivier GALLIENBest answer
    Dec 1, 2023 4:05 PM UTC
    Hi @nitgbhat ,
    stm32mp1xx*.dtb notation intend to be generic to all ST boards.
    xx might be replaced by chip/board reference you target. Probably stm32mp157f-dk2.dts in your case.
    Olivier
    Olivier GALLIEN
    Hi @nitgbhat ,
    Olivier
