浩侯.1
Dec 30, 2020 05:31 UTC
Problems with the stm32_rpmsg_sdb.c
I find the kernel Panic when I mmap 16 shared memory regions.(4KB/memory)
Olivier GALLIEN
Jan 4, 2021 09:30 UTC
Please confirm you are trying to play with provided example https://wiki.st.com/stm32mpu/wiki/How_to_exchange_large_data_buffers_with_the_coprocessor_-_example
In which ecosystem context are you ?
Please check that memory mapping is consistent between kernel dts and MP4 firmware for shared memory.
Olivier
TBlec.1
Mar 10, 2021 05:34 UTC
running into the same issue it looks like there's a simple buffer overflow in the `sprintf` when trying to print an index larger than 9:
https://github.com/STMicroelectronics/meta-st-stm32mpu-app-logicanalyser/pull/3/commits/14b3ddbda9cf7d2413479fb7fbd6aebc0d626a0f
