Dec 11, 2020 05:21 UTC
Please tell me about what "st-image-xxxxx" parameter means.
I want to know what "st-image-xxxxx" parameter mean.
Especially, I want to know what name of xxxxx (for example "weston") means.
Is the name of xxxxx related to the name of some config file?
For example, if I changed the name of xxxxx to any name from weston, Are output files by bitabake influenced?
​Best Regards,
H. Masuda.
KnarfB
KnarfBBest answer
Dec 11, 2020 11:58 UTC
Its the name of the recipe file in layers/meta-st-openstlinux/recipes-st/images/. So you might look up the recipe and see what else is possible or change the recipe according to your needs (Best done in your own layer).
KnarfB
KnarfBBest answer
HMasu.1Author
Dec 16, 2020 02:17 UTC
Hi @KnarfB​
Thank you for your reply.
I understood very well.
So, when we create our own machine, Should we create our own layer(meta-***), and create recipe file in our own layer instead of using "weston"?
H. Masuda
