BBoge.2
Jan 10, 2023 10:11 UTC
OTP 3 Bit 15 -> no data cache
What does the OTP 3 Bit 15 do?
0693W00000Y7paKQAR.pngCan I disable the boot cache for more security? Or does it have more impact on the system?
PatrickF
PatrickFBest answer
Jan 10, 2023 12:20 UTC
this bit is for ST internal development purposes, it is recommended to keep it at 0.
Disabling does not bring more security as cache is not used by BootROM in critical authentication phases but only to speed up signature verification. I think cache content is erased before BootROM exit.
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
PatrickF
PatrickFBest answer
BBoge.2
BBoge.2Author
Jan 11, 2023 06:16 UTC
Thank you for the fast support.
