Oitsh.1
Dec 23, 2020 10:48 UTC
OTG_VBUS
I am not using OTG (Only host USB's) in the PCB I connected OTG_VBUS to GND. Is this problematic? I saw that it should be left open but not sure if it is connected internally
PatrickF
PatrickFBest answer
Jan 4, 2021 07:37 UTC
That's ok.
Btw, you did not use USB OTG in uBoot during your board Flashloading ? This is anyway possible without using VBUS pin, see https://wiki.st.com/stm32mpu/wiki/How_to_configure_U-Boot_for_your_board#USB_OTG_node
Regards.
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
PatrickF
PatrickFBest answer
That's ok.
Regards.
