Apr 15, 2024 12:58 UTC
Networks settings
Each time I reboot my Discovery kit with STM32MP135F borad I lost the network (IP V4 address).
How can I set the IP address, Does exits somewhere a /etc/network/interface file ?
Thank you,
Olivier.
Jean-Marc B
Jean-Marc BBest answer
Apr 15, 2024 14:04 UTC
Hi @Olivier73
This wiki page https://wiki.st.com/stm32mpu/wiki/How_to_configure_ethernet_interface#STATIC_configuration may help you.
Best regards,
--JM
Andrew Neil
Apr 15, 2024 13:00 UTC
Does it not do DHCP?
Olivier73Author
Apr 15, 2024 13:05 UTC
I want to use static IP address like 192.168.0.10.
so I send :
ifconfig eth0 192.16.0.10 netmask 255.255.255.0
then it works
but if i reboot the board I lost the network.
I would like to know wich file I need to setup.
Thank you
Jean-Marc B
Hi @Olivier73
Best regards,
--JM
