Jzhua
Nov 6, 2020 02:06 UTC
Network cable compatibility issues
when i using a 100M network cable in a gigabit network,It should be recognized as a 100M network under normal circumstances,But STM32MP1 is recognized as Gigabit,at this time the network is useless,led is light but not blink,I changing cable to a Gigabit Ethernet cable solved the problem,I am using stm32mp157c-dk2
PatrickF
PatrickFBest answer
Nov 24, 2020 07:42 UTC
This is confirmed as a regression on the Realtek RTL8211F community driver for kernel 5.4.
RTL8211E used on STM32MP157x-EV1 is not affected.
This is not related to ST work (although we should have discovered this regression), we are checking for a patch or a solution.
I keep you posted if I see progress.
Regards.
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
PatrickF
Nov 9, 2020 10:48 UTC
a similar issue is under analysis internally. I will make an update when I get feedback.
PatrickF
PatrickFBest answer
Regards.
