Sep 22, 2026 2:55 PM UTC
MP2 REV Y ETH1 RGMII stability and recommendation
​@Erwan SZYMANSKI, we are about to design a new hardware based on MP2.
Is REV Y ETH1 port stable when used in RGMII mode?
Is this config recommended?
ETH1 in RGMII mode and ETH2 in RMII
Erwan SZYMANSKI
Erwan SZYMANSKIBest answer
Sep 22, 2026 2:58 PM UTC
Hello ​@Bulcsu,
Yes I confirm that there is no issue on RGMII side for ETH1, so your combination ETH1 RGMII + ETH2 RMII will work perfectly fine.
Kind regards,
Erwan.
Erwan SZYMANSKI
Hello ​@Bulcsu,
Kind regards,
Erwan.
BulcsuAuthor
Oct 6, 2026 2:06 PM UTC
Thank You for the confirmation.
