Dat Tran
Senior II
Nov 10, 2022 15:51 UTC
mmci-pl18x 58005000.mmc: no support for card's volts
We don't use PMIC so we remove vmmc-supply = <&v3v3>; in device tree.
what should be in vmmc-supply if we connect SD_VDD constantly to 3.3V, no pmic?
Many thanks
info
infoBest answer
Nov 15, 2022 10:38 UTC
I have done the same - no STPMIC chip.
You need to declare a fixed voltage power supply in your device tree and use it with the MMC. If you do not do that the MMC driver will not initialize.
You will have to do similar with USB if you plan on using that.
Add to your root node (or where ever suitable}
vmmc: regulator@0 {
compatible = "regulator-fixed";
reg = <0>;
regulator-name = "vmmc";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-always-on;
&sdmm1 ( //choose your mmc (1,2,3) here
vmmc-supply = <&vmmc>
info
infoBest answer
vmmc: regulator@0 {
reg = <0>;
Dat Tran
Dat TranAuthor
Senior II
Dec 2, 2022 14:56 UTC
Thank you, yes that was it.
