SNaza.1
Jul 8, 2021 10:42 UTC
Is there a way to load U-boot on STM32MP1 via dfu-util instead of STM32CubeProgrammer?
I want to use open source utilities to load U-boot into SRAM in "Serial mode". Is it possible?
P.S. As I can see, there is an article about it on ST Wiki, but an access to it is restricted for regular users: https://wiki.st.com/stm32mpu/wiki/How_to_load_U-Boot_with_dfu-util
How to gain access to this article for an ordinary user?
Olivier GALLIEN
Olivier GALLIENBest answer
Jul 8, 2021 14:12 UTC
Hi @SNaza.1​ ,
Wiki article is online. Enjoy ! ;)
Olivier
Jean-Marc B
Jul 8, 2021 12:10 UTC
Hi @SNaza.1​
I guess the wiki page you refer is not yet approved for public delivery hence its restricted access. @Community member​ , could you confirm?
Anyway, you may find useful information in this public application note: https://www.st.com/resource/en/application_note/dm00589815-usb-dfu-usart-protocols-used-in-stm32mp1-series-bootloaders-stmicroelectronics.pdf
The open source utility dfu-util may be used to perform the load of U-boot on STM32MP1.
Best regards,
--JM
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
Olivier GALLIEN
Jul 8, 2021 12:14 UTC
Hi @SNaza.1​ , @Jean-Marc B​ ,
Yes the wiki page is under final review and close to be published.
Keep you posted here soon.
Olivier
Olivier GALLIEN
Hi @SNaza.1​ ,
Olivier
PatrickF
Jul 9, 2021 11:42 UTC
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
