rahuj.1
Nov 28, 2022 04:00 UTC
is it possible disable buck boost regulator 3.3 (stm32mp157c pmic) during system suspend from dtsi configs ?
PatrickF
PatrickFBest answer
Nov 28, 2022 13:12 UTC
Hi @rahuj.1​
During system STANDBY, the VDD (usually STPMIC1 buck3) must be kept powered in order to allow wake-up from STM32MP15x RTC/TAMP IP or WKUP pins (which will make PWR_ON pin to go high which ask STPMIC1 to restore supplies which has been shutdown). Other supplies are usually shutdown if not requested by peripherals (managed by Linux).
If you want to fully shutdown the system, this is possible by asking STPMIC1 to completely shutdown, but then, only STPMIC1 could power-on again the system (from STPMIC1 PONKEYn or WAKEUP pins).
See also https://wiki.st.com/stm32mpu/wiki/Regulator_overview
and https://wiki.st.com/stm32mpu/wiki/How_to_define_your_low-power_strategy
Regards.
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
PatrickF
PatrickFBest answer
Hi @rahuj.1​
Regards.
