jvog.sen
Jul 22, 2022 09:35 UTC
Inaccurate measurement of VREFINT
Hi everyone!
I see unexpected values when measuring VREFINT. The ADC measures around 1.18V, on some boards even 1.16V, which is outside the tolerance according to the datasheet:0693W00000QLsweQAD.png
Reading the calibration value VREFIN_CAL from OTP memory returns a value of 0x5E29 (1,214V).
Considering my ambient temperature of ~25°C, I would not expect the measured value to differ too much from VREFINT_CAL.
I then used VREFIN_CAL to calculate VREF+ according to section 29.4.35 in RM0436:
0693W00000QLsozQAD.pngWith the ADC-measurement of VINTREF, this calculates to VREF+= 2.57V. The actual voltage (measured with a multimeter) is 2.502V.
All the other ADC channels are pretty accurate.
My DeviceTree setup for ADC2:
adc2:adc@100{
	st,adc-channels = <12 13 14>;
	st,min-sample-time-nsecs = <50000>;
	assigned-resolution-bits = <16>;
	status = "okay";
	channel@12 {
		reg = <12>;
		label = "vsense";
		status = "okay";
	channel@13 {
		reg = <13>;
		label = "vrefint";
		status = "okay";
	channel@14 {
		reg = <14>;
		label = "vddcore";
		status = "okay";
PatrickF
PatrickFBest answer
Jul 22, 2022 13:24 UTC
sorry there is typo in the wiki, "min-sample-time-nsecs" is ok.
We are checking internally, but meanwhile, could you try putting sample time defintion inside each channel ?
e.g.
 adc2:adc@100{
 	status = "okay";
 	channel@12 {
 		reg = <12>;
 		label = "vsense";
 		status = "okay";
 	channel@13 {
 		reg = <13>;
 		label = "vrefint";
 		status = "okay";
 	channel@14 {
 		reg = <14>;
 		label = "vddcore";
 		status = "okay";
Regards.
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
PatrickF
Jul 22, 2022 12:59 UTC
Hi @jvog.sen​
maybe a typo in your DT which end up to a too short sample time (as per datsheet should be above 4.3us for VREFINT)
min-sample-time-nsecs ==> min-sample-time-nsec (assuming you are on Ecosystem v3.1)
See also https://wiki.st.com/stm32mpu/wiki/ADC_device_tree_configuration#Channel_properties_-28for_ecosystem_release_-E2-89-A5_v3-1-0_-29
Regards.
PatrickF
PatrickFBest answer
e.g.
 adc2:adc@100{
 	status = "okay";
 	channel@12 {
 		reg = <12>;
 		label = "vsense";
 		status = "okay";
 	channel@13 {
 		reg = <13>;
 		label = "vrefint";
 		status = "okay";
 	channel@14 {
 		reg = <14>;
 		label = "vddcore";
 		status = "okay";
Regards.
jvog.sen
jvog.senAuthor
Jul 22, 2022 13:50 UTC
Hi Patrick,
Thanks for the quick response. I will try this next week!
Jan
PatrickF
Jul 25, 2022 12:28 UTC
Hi @jvog.sen​
Please confirm you are using ecosystem v3.1 (Linux kernel 5.10) or v4.0 (Linux Kernel v5.14) ?
Regards.
jvog.sen
jvog.senAuthor
Jul 27, 2022 07:54 UTC
Hi Patrick,
I am currently using ecosystem v3.1.
Jan
