MEdma.1
Nov 10, 2022 16:34 UTC
I'm using a processor module based around STM32MP157C processor - we're ready to go to production. It's programmed with Linux and our application. We've been using Cube32 to program, but it takes 40 minutes to program. How can I program fast over USB
Eldam
EldamBest answer
Senior
Nov 14, 2022 11:41 UTC
If you're talking about programming emmc,
we use a sdcard with minimal distri on it,
we boot on sdcard
we use script to format emmc,
from there, we copy the content from the sdcard (or usb inserted disk)
and after we boot to emmc.
Uwe Bonnes
Chief
Nov 10, 2022 20:09 UTC
How does programming happen?
Nov 10, 2022 21:36 UTC
USB-FS vs USB-HS ? ST-LINKV/V2 vs V3?
Slow ports, or hubs?
Perhaps use USB to deliver a smaller u-boot payload, and have that pull and program the main image broadcast in a loop with Ethernet?
Make the image smaller?
Use SD Card?
MEdma.1
MEdma.1Author
Nov 14, 2022 09:31 UTC
It's programmed over high speed USB. I prefer to use the image built according to manufacturer's recommendations. We are not Linux experts here, so changing the build too much has some risk. I think your suggestion about downloading a small u-boot payload is what the Elpotronic Gangflasher software does, but we can't get it to work right now.
Eldam
EldamBest answer
Senior
we boot on sdcard
