Hungchul.Shin
How to work with A7-core with IAR?
Can't a7-core write firmware with a generic compiler like IAR without Linux?
Like working with tools like ADS Compiler , like s3c6440 .....
You can compile with GNU/GCC running under Windows.​
Ozone
Principal
You need to check if the compiler supports the specific core (Cortex A7), and the toolchain comes with the required environment (Linux header files, device-specific drivers, and libs).
Microcontroller specific ones like IAR and Keil usually do not.
