Jun 26, 2024 08:18 UTC
How to send/receive Ethernet packets in STM32MP157
I want to send and receive data using Ethernet.
I tried this Linux version code, but it didn't works. https://gist.github.com/austinmarton/1922600
After I failed to try, I found this header code, STMMAC.
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/drivers/net/ethernet/stmicro/stmmac/stmmac.h
Should I make a program based on this code??
I've searched a lot, but I couldn't find any related cases.
I'm not good enough to make the whole program code.
If you have any relevant content or examples, please let me know....
Olivier GALLIEN
Jun 28, 2024 12:19 UTC
Hi @inkong ,
Not sure to get your question
Ethernet can be manage by OpenSTLinux
refer to How to configure ethernet interface - stm32mpu
Ethernet overview - stm32mpu
Olivier
Jul 16, 2024 14:38 UTC
If you want to generate data over the ethernet port (just to validate or something) you could use for instance command line from linux (e.g. wget)
https://linux.die.net/man/1/wget
To download an image in an endless while loop for instance:
while [ 1 ]; do wget https://cdn.kernel.org/pub/linux/kernel/v6.x/linux-6.1.42.tar.gz; done;
 (it will do forever (untill stopped) a download of the kenrnel archive in tar.gz format, which is ~200 MB of size. )
