Jliu.21
Jan 28, 2021 13:33 UTC
How to make a SD-Card which is used to boot the system.
I have a question,I have no any USB-OTG interface can be used to help me burning and I can only use SD card to run my board. How can I make this SD-Card work only on linux command lines for example "dd" and so on. I have made tf-a uboot kernel(image) dtb and rootfs. I wish someone can help me ,thank you so much.
KnarfB
KnarfBBest answer
Jan 28, 2021 13:42 UTC
Jliu.21
Jliu.21Author
Jan 30, 2021 15:10 UTC
thank you! already done!
PatrickF
Jan 29, 2021 17:01 UTC
Hi @Jliu.2​ , Please click on 'Select as Best' if reply solved your issue or answered your question.
Regards.
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
