Jaison M
Jun 17, 2022 21:25 UTC
How to install aiortc (python module) in STM32MP157F-DK2
So basically I'm trying to implement WebRTC and seems like aiortc is its python implementation right now:.
Unable to manually install them using pip3 as it requires some dev-packages.
I tried to install it as a layer using pipoe auto-generated recipe, but no luck as it goes on with errors. A working recipe and additions that has to be done to local.conf or CORE_IMAGE_EXTRA_INSTALL variable would be appreciated :smiling_face_with_smiling_eyes:.
Jean-Marc B
Jean-Marc BBest answer
Jun 20, 2022 09:59 UTC
Hi @Jaison M​
This recipe generates a package that I have successfully installed on my board (stm32mp157c-dk2):
DESCRIPTION = "aiortc is a library for Web Real-Time Communication (WebRTC) and \
Object Real-Time Communication (ORTC) in Python."
HOMEPAGE = "https://github.com/aiortc/aiortc"
SECTION = "devel/python"
AUTHOR = "Jeremy Laine"
LICENSE = "BSD"
LIC_FILES_CHKSUM = "file://LICENSE;md5=907b5e856b2e6bcd8a3cc8d338a6166f"
SRC_URI[md5sum] = "3f43e88416113141b0196bdf6c37b444"
SRC_URI[sha256sum] = "15608d7fcf09502d1b8c19b8a63bc22966090ee0761ac9a755e9f747f46d67ab"
PYPI_PACKAGE = "aiortc"
DEPENDS += " \
 ${PYTHON_PN}-setuptools-scm-native \
 ${PYTHON_PN}-toml-native \
inherit pypi python_setuptools_build_meta
RDEPENDS:${PN} += " \
 ffmpeg \
 libopus \
 libsrtp \
 libvpx \
BBCLASSEXTEND += "native nativesdk"
I did this quick test with the OpenSTLinux distribution that should be released soon. Results may differ against OpenSTLinux ecosystem 3.1
Best regards,
--JM
Jean-Marc B
Hi @Jaison M​
LICENSE = "BSD"
DEPENDS += " \
 ffmpeg \
 libopus \
 libsrtp \
 libvpx \
Best regards,
--JM
Jaison M
Jaison MAuthor
Jun 20, 2022 14:07 UTC
Ok I tried compiling the layer, but received this error:
Could not inherit file classes/python_setuptools_build_meta.bbclass
How do I fix this?
Jean-Marc B
Jun 21, 2022 06:04 UTC
Hi @Jaison M​
As said, I didn't check with ecosystem-3.1 so I guess this error may be explained so.
For ecosystem-3.1, you could try to remove the DEPENDS variable and replace python_setuptools_build_meta inheritance by setuptools3.
Then, you could also downgrade the aiortc version as the internal build mechanism may not be compatible with ecosystem-3.1 but older versions may be compatible.
Best regards,
--JM
