MRall.1
Dec 1, 2021 08:24 UTC
How to enable the kernel splashscreen on STM32MP157 board , kernel 5.4 and LCD RGB interface ?
I'm using a STM32MP157a with yocto dunfell with 5.4 kernel version, and I'm trying to enable the kernel splashscreen. On my board I'm using the RBG lcd interface, and when the system is UP my application in showing curretly. On kernel config I have enabled the flags:
LOGO
LOGO_LINUX_CLUT224
FRAMEBUFFER_CONSOLE
but no tux are showing at startup...
Where I'm wrong ?
Kevin HUBER
Kevin HUBERBest answer
Jan 10, 2022 17:36 UTC
Hi @MRall.1​ ,
To enable the spashscreen when building from Yocto, you have to build these two recipes:
  • layers/meta-st/meta-st-openstlinux/recipes-core/psplash/psplash-drm
  • layers/openembedded-core/meta/recipes-core/psplash
The file psplash-drm.bb adds the file psplash-drm-start.service to your filesystem.
Once you are on the board, you must have something like that (I am on OpenSTLinux 5.10 so some paths may be different):
root@stm32mp1:/# find -name "psplash*"
./etc/systemd/system/local-fs.target.wants/psplash-drm-start.service
./lib/systemd/system/psplash-drm-start.service
./usr/bin/psplash-drm
./usr/bin/psplash-drm-quit
./var/lib/dpkg/info/psplash-drm.list
./var/lib/dpkg/info/psplash-drm.md5sums
./var/lib/dpkg/info/psplash-drm.postinst
./var/lib/dpkg/info/psplash-drm.prerm
Hope it helps,
Regards,
Kevin
Kevin HUBER
Hi @MRall.1​ ,
Hope it helps,
Regards,
Kevin
