populating SB18 with a 0 ohm will keep the embedded ST-Link in reset, thus reducing it's consumption to minimum . Other option could be to remove SB21. In both cases, there will be no way to debug nor use USB Virtual Comm port thru CN11.
No ways to disable it by SW.
Development boards are not power optimized, so, you might not reach best possible low power consumption due to design choice (e.g. board component supply directly on VDD, DDR3L with VTT terminations, etc...) and system components (such as STLINK, LED, pull-up, pull-down, etc...).
Maybe look at this post : https://community.st.com/s/question/0D53W00000lzCWVSA2/power-management-with-stm32mp15x-and-openampttyechowakeup-example
Regards.
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
