Mario Luzeiro
Apr 22, 2022 09:55 UTC
How to catch and handle M4 watchdog crashes on Linux side?
I managed to make the M4 WWDOG to work.
I got on Linux cmd line:
remoteproc remoteproc0: crash detected in m4: type watchdog
How can I catch and handle this events programmatically on a shell script, C or Python ?
ArnaudP
ArnaudPBest answer
Apr 29, 2022 15:13 UTC
Hello Mario,
Different strategies are possible.
1) The polling method
  • disable the auto recovery
echo disabled >/sys/class/remoteproc/remoteproc0/recovery
  • poll the remoteproc state, looking for the "crashed" stated
cat /sys/class/remoteproc/remoteproc0/state
  • recover the M4
echo recover >/sys/class/remoteproc/remoteproc0/recovery
2) Use coredump trigger
An event is sent to the userspace application on crash to save the coredump, this can also be used to detect the crash
Details and link to udev script are available on this page:
https://wiki.st.com/stm32mpu/wiki/How_to_retrieve_Cortex-M4_logs_after_crash
3) Create your own udev trigger based on virtio device add/remove ( work only if you use RPMsg)
this page provide details on how to implement it:
https://www.tecmint.com/udev-for-device-detection-management-in-linux/
The rules to implement is:
SUBSYSTEM=="virtio", ACTION=="add", RUN+="/bin/device_added.sh"
SUBSYSTEM=="virtio", ACTION=="remove", RUN+="/bin/device_removed.sh"
4) tips to ease your test
you can simulate a watchdog crash using following command:
echo 1 >/sys/kernel/debug/remoteproc/remoteproc0/crash
Regards,
Arnaud
ArnaudP
ArnaudPBest answer
Hello Mario,
  • recover the M4
Regards,
Arnaud
