Yli.8
How to add modified device tree with PWM control backlight
My circuit board USES PE6 to control the backlight, but it cannot be adjusted. How to modify the device tree of TIM15_CH2.EV1 is not regulated.
EV1:
panel_backlight: panel-backlight {
compatible = "gpio-backlight";
gpios = <&gpiod 13 GPIO_ACTIVE_LOW>;
default-on;
status = "okay";
Olivier GALLIEN
Hi @昌�?� �?�​
It's not clear to me if you need help to write the device tree or to compile/load it to your system.
Anyway, if not done please refer to following link which might help you.
For Device tree modification around Timer/PWM :
https://wiki.st.com/stm32mpu/wiki/PWM_overview
https://wiki.st.com/stm32mpu/wiki/TIM_device_tree_configuration
For building and applying Device Tree :
https://wiki.st.com/stm32mpu/wiki/How_to_cross-compile_with_the_Developer_Package
Hope it help
Olivier
Yli.8
Yli.8Author
Sorry, what I want to explain is how to use PWM to control backlight?
