Apr 30, 2025 3:10 AM UTC
How do i verify my dts modification with faster way(not bitbake whole image always)
Hi ST:
I am devloping the STM32MP131c  with yocto package
Everytime after i modify the dts using devtool, i need to
bitbake st-image-core
and flash all image with stm32cubeprogramming tool
There is a ethernet on my board
Is there any faster way to help me verify my dts modification
Maybe compile the dtb only and scp into DUT
or compile bootfs only and i can only flash the bootfs partition
Thank you
Erwan SZYMANSKI
Erwan SZYMANSKIBest answer
Apr 30, 2025 1:29 PM UTC
Hello @Jordan_Lin ,
Yes, you can use what we call the Developer Package (with SDK) to just cross compile the SW component you want to test, or here in this situation, just compile your device tree modified.
The wiki article is here: https://wiki.st.com/stm32mpu/wiki/STM32MPU_Developer_Package
Then, as you said, a device tree modification is simple to test as you can just replace the existing one in the bootfs partition of your flash memory.
Kind regards,
Erwan.
Erwan SZYMANSKI
Hello @Jordan_Lin ,
Kind regards,
Erwan.
