msche.1
Feb 3, 2022 03:21 UTC
How do I fix "undefined reference to `OPENAMP_create_endpoint'" within the OpenAmp source.
I've added OPENAMP through the middleware after enableing the IPCC interrupts, but now I'm getting the following error and an error in the actual OPENAMP source that's included!
/opt/st/stm32cubeide_1.8.0/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.9-2020-q2-update.linux64_2.0.0.202105311346/tools/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld: ./Core/Src/main.o: in function `main':
/home/mschem/Gown-Sealer/STM32/sealer/CM4/Debug/../Core/Src/main.c:127: undefined reference to `MX_OPENAMP_Init'
/opt/st/stm32cubeide_1.8.0/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.9-2020-q2-update.linux64_2.0.0.202105311346/tools/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld: /home/mschem/Gown-Sealer/STM32/sealer/CM4/Debug/../Core/Src/main.c:172: undefined reference to `OPENAMP_check_for_message'
/opt/st/stm32cubeide_1.8.0/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.9-2020-q2-update.linux64_2.0.0.202105311346/tools/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld: ./Middlewares/Third_Party/OpenAMP/virt_uart.o: in function `VIRT_UART_Init':
/home/mschem/Gown-Sealer/STM32/sealer/Middlewares/Third_Party/OpenAMP/virtual_driver/virt_uart.c:76: undefined reference to `OPENAMP_create_endpoint'
collect2: error: ld returned 1 exit status
make: *** [makefile:66: test_CM4.elf] Error 1
"make -j4 all" terminated with exit code 2. Build might be incomplete.
Olivier GALLIEN
Mar 16, 2022 11:06 UTC
Hi @msche.1​ ,
Sorry to come late on this post.
I guess you find solution by yourself ?
Function OPENAMP_create_endpoint is declared in openamp.c/openamp.h
Olivier
