Mar 13, 2024 17:38 UTC
Failed on OPTEE: F/TC:0 0 probe_driver_node:391 Probing stm32mp1-cpu-opp on node cpu0-opp-table
I tried port optee to customize board, but encouted panic and I could not figure it out. here is log and dree tree setting for the board, thank you
scotzBest answer
Mar 13, 2024 21:34 UTC
Fixed by adding
/* Regulators */
    vdd: regulator-vdd {
        compatible = "regulator-fixed";
        regulator-name = "vdd";
        regulator-min-microvolt = <3300000>;
        regulator-max-microvolt = <3300000>;
        regulator-always-on;
    vddcore: vddcore {
        regulator-name = "vddcore";
        regulator-min-microvolt = <1200000>;
        regulator-max-microvolt = <1200000>;
&cpu0{
    cpu-supply = <&vddcore>;
&cpu1 {
scotzAuthorBest answer
Fixed by adding
/* Regulators */
    vddcore: vddcore {
&cpu0{
&cpu1 {
