OHaza.1
Nov 24, 2020 08:17 UTC
Error trying to build dtb
Hi, I tried to follow the example in the youtube workshop, moving a pwm timer to the a7 side. I was able to create a dts file with cube mx but when running make to build the dtb i get
"reference to non existent node or label "ethernet_mac_address""
Is it possibly some mismatch between versions of cube and the openst dist?
Olivier GALLIEN
Nov 24, 2020 10:15 UTC
Hi @OHaza.1​ ,
Refer to wiki release note to check consistency between OpenST version and tools
Olivier
OHaza.1
OHaza.1Author
Nov 24, 2020 15:44 UTC
Ok, thanks, looks like things have changed in the last few days/weeks, so could well be that.
