SScar.2
Senior
Nov 9, 2022 15:54 UTC
ERROR during bitbake: st-image-resize-initrd.bb: ENABLE_PARTITIONS_IMAGE not enabled
Hi there,
I'm following all the steps described in Distribution-package to compile the yocto build for STM32MP157F-DK2 (stm32mp1). And at the beginning of the compilation (bitbake st-image-weston) I am getting the message :
.....openstlinux-5.15-yocto-kirkstone-mp1-v22.06.15/layers/meta-st/meta-st-openstlinux/recipes-st/images/st-image-resize-initrd.bb: ENABLE_PARTITIONS_IMAGE not enabled
is it a problem? Did I miss something?
Simone
Olivier GALLIEN
Olivier GALLIENBest answer
Nov 9, 2022 16:00 UTC
Hi @SScar.2​ ,
Looks to be a known issue of V4.0.0. Recommand to switch to 4.0.2
see :
https://community.st.com/s/question/0D53W00001kqThySAE/enablepartitionsimage-not-enabled
and
OpenSTLinux Distribution patch release V4.0.2 is available
Olivier
Olivier GALLIEN
Hi @SScar.2​ ,
see :
and
Olivier
SScar.2
SScar.2Author
Senior
Nov 9, 2022 16:03 UTC
Hi Olivier,
I totally missed that, I will try that solution. Thanks!
EDIT: the message is still there. I will see if it's a problem for compilation or not
EDIT 2: the compilation succeded ​
