manishee
Jan 8, 2024 11:23 UTC
error at PMIC I2C
We have set PB7 and PE15 for  I2c4 communication for PMIC in op-tee stm32mp135f-dk.dts.
but we keep getting pmic error like this -
I/TC: Embedded DTB found
I/TC: OP-TEE version: Unknown_3.19 (gcc version 12.2.0 (GCC)) #23 Mon Jan 8 10:50:26 UTC 2024 arm
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: WARNING: All debug access are allowed
E/TC:0 0 Panic at core/arch/arm/plat-stm32mp1/drivers/stm32mp1_pmic.c:183 <initialize_pmic_i2c>
E/TC:0 0 TEE load address @ 0xde000000
E/TC:0 0 Call stack:
E/TC:0 0 0xde0030f9
E/TC:0 0 0xde0193a7
E/TC:0 0 0xde006735
E/TC:0 0 0xde017fb9
E/TC:0 0 0xde018089
E/TC:0 0 0xde018773
E/TC:0 0 0xde01a095
E/TC:0 0 0xde002fbb
E/TC:0 0 0xde00019c
Feb 2, 2024 07:25 UTC
I have the exact same issue with PB7 and PE15. Have you been able to solve this issue?
Feb 13, 2024 04:07 UTC
Here is the PMIC and power related DeviceTree parts that works for me.
optee-os dts:
(Use this part same in tf-a dts file.)
/ { /* root */
    vin: vin {
        compatible = "regulator-fixed";
        regulator-name = "vin";
        regulator-min-microvolt = <5000000>;
        regulator-max-microvolt = <5000000>;
        regulator-always-on;
    v3v3_ao: v3v3_ao {
        regulator-name = "v3v3_ao";
        regulator-min-microvolt = <3300000>;
        regulator-max-microvolt = <3300000>;
Check that under &etzpc node you have I2C4 secured
DECPROT(STM32MP1_ETZPC_I2C4_ID, DECPROT_S_RW, DECPROT_UNLOCK)
(Use this part (i2c4 node) same in tf-a dts file.)
&i2c4{
    pinctrl-names = "default";
    pinctrl-0 = <&i2c4_pins_mx>;
    status = "okay";
    /* USER CODE BEGIN i2c4 */
    clock-frequency = <400000>;
    i2c-scl-rising-time-ns = <185>;
    i2c-scl-falling-time-ns = <20>;
    pmic: stpmic@33 {
        compatible = "st,stpmic1";
        reg = <0x33>;
        status = "okay";
        st,wakeup-pin-number = <1>;
        st,notif-it-id = <0>;
        wakeup-source;
        regulators {
            compatible = "st,stpmic1-regulators";
            buck1-supply = <&vin>;
            buck2-supply = <&vin>;
            buck3-supply = <&vin>;
            buck4-supply = <&vin>;
            ldo1-supply = <&vin>;
            ldo4-supply = <&vin>;
            ldo5-supply = <&vin>;
            ldo6-supply = <&vin>;
            vref_ddr-supply = <&vin>;
            pwr_sw1-supply = <&bst_out>;
            pwr_sw2-supply = <&v3v3_ao>;
            vddcpu: buck1 {
                regulator-name = "vddcpu";
                regulator-min-microvolt = <1250000>;
                regulator-max-microvolt = <1350000>;
                regulator-over-current-protection;
                lp-stop {
                    regulator-suspend-microvolt = <1250000>;
                lplv-stop {
                    regulator-suspend-microvolt = <900000>;
                lplv-stop2 {
                    regulator-off-in-suspend;
                standby-ddr-sr {
                standby-ddr-off {
            vdd_ddr: buck2 {
                regulator-name = "vdd_ddr";
                regulator-min-microvolt = <1350000>;
                standby-ddr-off {
            vdd: buck3 {
                regulator-name = "vdd";
                st,mask-reset;
            vddcore: buck4 {
                regulator-name = "vddcore";
                regulator-max-microvolt = <1250000>;
                lplv-stop {
                lplv-stop2 {
                standby-ddr-sr {
                standby-ddr-off {
            vdd_adc: ldo1 {
                regulator-name = "vdd_adc";
                standby-ddr-sr {
                standby-ddr-off {
            unused1: ldo2 {
                regulator-name = "ldo2";
            unused2: ldo3 {
                regulator-name = "ldo3";
            vdd_usb: ldo4 {
                regulator-name = "vdd_usb";
                standby-ddr-sr {
                standby-ddr-off {
            vdd_sd: ldo5 {
                regulator-name = "vdd_sd";
                regulator-boot-on;
                standby-ddr-sr {
                standby-ddr-off {
            v1v8_periph: ldo6 {
                regulator-name = "v1v8_periph";
                regulator-min-microvolt = <1800000>;
                regulator-max-microvolt = <1800000>;
                standby-ddr-sr {
                standby-ddr-off {
            vref_ddr: vref_ddr {
                regulator-name = "vref_ddr";
                standby-ddr-sr {
                standby-ddr-off {
            bst_out: boost {
                regulator-name = "bst_out";
            v3v3_sw: pwr_sw2 {
                regulator-name = "v3v3_sw";
                regulator-active-discharge = <1>;
    /* USER CODE END i2c4 */
I also have this node added but I don't think you need it to PMIC work:
&pwr_regulators{
    status = "okay";
    /* USER CODE BEGIN pwr_regulators */
    system_suspend_supported_soc_modes = <
        STM32_PM_CSLEEP_RUN
        STM32_PM_CSTOP_ALLOW_LP_STOP
        STM32_PM_CSTOP_ALLOW_LPLV_STOP
        STM32_PM_CSTOP_ALLOW_LPLV_STOP2
        STM32_PM_CSTOP_ALLOW_STANDBY_DDR_SR
    system_off_soc_mode = <STM32_PM_SHUTDOWN>;
    vdd-supply = <&vdd>;
    vdd_3v3_usbfs-supply = <&vdd_usb>;
    /* USER CODE END pwr_regulators */
and make sure you have secured you I2C4 pins. For me:
&gpiob {
    st,protreg = < (TZPROT(9)|TZPROT(13)) >;
but for you it shoud be something like this:
&gpiob { /* PB7 */
    st, protreg = < (TZPROT(7))>;
&gpioe { /* PE15 */
    st, protreg = < (TZPROT(15))>;
/* Add this part also under the u-boot and kernel dts file /*
&scmi_regu {
    scmi_vddcpu: voltd-vddcpu {
        reg = <VOLTD_SCMI_STPMIC1_BUCK1>;
        voltd-supply = <&vddcpu>;
    scmi_vdd: voltd-vdd {
        reg = <VOLTD_SCMI_STPMIC1_BUCK3>;
        voltd-supply = <&vdd>;
    scmi_vddcore: voltd-vddcore {
        reg = <VOLTD_SCMI_STPMIC1_BUCK4>;
        voltd-supply = <&vddcore>;
    scmi_vdd_adc: voltd-vdd_adc {
        reg = <VOLTD_SCMI_STPMIC1_LDO1>;
        voltd-supply = <&vdd_adc>;
    scmi_vdd_usb: voltd-vdd_usb {
        reg = <VOLTD_SCMI_STPMIC1_LDO4>;
        voltd-supply = <&vdd_usb>;
    scmi_vdd_sd: voltd-vdd_sd {
        reg = <VOLTD_SCMI_STPMIC1_LDO5>;
        voltd-supply = <&vdd_sd>;
    scmi_v1v8_periph: voltd-v1v8_periph {
        reg = <VOLTD_SCMI_STPMIC1_LDO6>;
        voltd-supply = <&v1v8_periph>;
    scmi_v3v3_sw: voltd-v3v3_sw {
        reg = <VOLTD_SCMI_STPMIC1_PWR_SW2>;
        voltd-supply = <&v3v3_sw>;
I hope it would solve your problem with PMIC.
Feb 27, 2024 01:46 UTC
@manishee and @arifbalik  did you guys solved your issues?
Jun 12, 2024 06:18 UTC
Yes, it turns out the pin should be inside the secure context. Changing this solved the issue for me
&gpiob{
    st,protreg = < (TZPROT(9) | TZPROT(7)) >;
