JOhn1
Aug 31, 2022 12:47 UTC
Enabling all clocks TF-A, what could go wrong?
Hello we are using STM32mp153 for multiple products, and I'm considering buiding a generic TF-A bootloader with one device tree with all the clocks enabled for all the peripherals.
I would like to do this in order to make it more generic across our portfolio.
Does this come with any potential problems down the line?
OlivierK
OlivierKBest answer
Sep 5, 2022 08:38 UTC
Hi JOhn (Community Member),
No I don't see any issue enabling all the available clocks in TF-a, if power consumption is not an issue for you. Indeed customisation is made in DT at U-boot and/or Linux level depending of your needs.
Regards,
Olivier
OlivierK
Sep 2, 2022 15:53 UTC
TF-A is normally restricted to the minimal configuration to enable system an security compoments. However just enabling all the peripheral clocks available in TF-A is not an issue. What kind of problems are you thinking about?
JOhn1
JOhn1Author
Sep 5, 2022 05:47 UTC
Basically if possible, I would like to reeuse the TF-a for different products.
This is so that specialization can happen at the linux devicetree level, saving efforts when adapting new products.
We have a large portfolio of products we are migrating to STM32mp, and savings in complexity are well worth it.
What I mean is that we then can avoid building a fully custom TF-A for each product, but can remain on one.
OlivierK
OlivierKBest answer
Regards,
Olivier
