Gencay
Aug 22, 2022 07:33 UTC
ENABLE_PARTITIONS_IMAGE not enabled
When I change the download directory for my yocto project in my local.conf file, this note pops up, what is this and should I do anything about it.
NOTE: /home/gencay/STM32MPU_workspace/openstlinux-5.15-yocto-kirkstone-mp1-v22.06.15/layers/meta-st/meta-st-openstlinux/recipes-st/images/st-image-resize-initrd.bb: ENABLE_PARTITIONS_IMAGE not enabled:45
Olivier GALLIEN
Olivier GALLIENBest answer
Aug 29, 2022 16:16 UTC
Hi @Gencay​ ,
Could you confirm this behavior was somewhat a side effect / symptom of the issue you reported in same timeframe in
meta-st-stmp32-addons variable issue ecosystem v4.0.0 - Kirkstone
Is it solve with DV4.0.2 ?
Olivier
Olivier GALLIEN
Hi @Gencay​ ,
Olivier
Gencay
GencayAuthor
Aug 31, 2022 06:13 UTC
Well, I did the update and it seems okay for my first build. I'll let you know if it pops up again. Thank you for your help.
