Ara.1
Mar 25, 2022 16:46 UTC
disable and enable all interrupt in stm32mp1
Is there any way to disable and enable all interrupts in a assembly way, because i need to manually switch on and OFF particular GPIO before UBOOT SPL start
uboot-source/board/st/stm32mp1/board.c
void board_debug_uart_init(void)
// disable interrupts ---- need support here
//PWM self logic written
// enable interrupts ---- need support here
PatrickF
Apr 15, 2022 12:47 UTC
Hi @Ara.1​
is that you asked for ?
void Enable_Irq(void)
 unsigned long temp;
 __asm__ __volatile__("mrs %0, cpsr\n"
 "bic %0, %0, #0x80\n"
 "msr cpsr_c, %0"
 : "=r" (temp)
 : "memory");
void Disable_Irq(void)
 unsigned long temp;
 "orr	%0, %0, #0x80\n"
 "msr cpsr_c, %0"
 : "=r" (temp)
 : "memory");
void Enable_Fiq(void)
 unsigned long temp;
 "bic %0, %0, #0x40\n"
 "msr cpsr_c, %0"
 : "=r" (temp)
 : "memory");
void Disable_Fiq(void)
 unsigned long temp;
 "orr	%0, %0, #0x40\n"
 "msr cpsr_c, %0"
 : "=r" (temp)
 : "memory");
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
