Jul 26, 2023 17:18 UTC
Difficulty with 1GB DDR3L memory routing and STM32MP151DAC1
I'm having some difficulty routing 1GB DDR3L memory with the STM32MP151DAC1. Both reference boards available for this product use different memory or pitch configurations.
I found an Application Note, AN5122, that guides through memory routing, but I would like some actual reference design example, to compare. There are any reference, ap notes, or anything to help with this?
Regards,
Arion Doneda
PatrickF
PatrickFBest answer
Jul 28, 2023 09:54 UTC
Hi @ariondoneda ,
I guess you overlooked the following file which is provided together with AN5122
STM32MP15x Series DDR memory routing guidelines examples
you will find routing examples for STM32MP15 in 'AC' 12x12 package with one or two DDR3L x16.
Regard.
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
PatrickF
PatrickFBest answer
Hi @ariondoneda ,
Regard.
Aug 3, 2023 12:41 UTC
Hi @PatrickF !
Well, i did not found this files before. Thank you very much!! Will help a lot!
Regard,
Arion Doneda
