Jul 8, 2026 12:56 PM UTC
DDR3L Configuration
I intend to use two 8-bit DDR3L memory devices with the STM32MP257FAK3. Could you kindly confirm whether this configuration is supported?
Looking forward for your response.
Regards,
Shubham
mƎALLEm
mƎALLEmBest answer
Jul 8, 2026 1:21 PM UTC
This questions must be asked in the “STM32 MPUs Products and hardware related” forum board not in “STM32 MCUs Products”
I’m moving the post then ..
Jul 8, 2026 1:17 PM UTC
how many density DDR3 do you want to connect to STM32? not sure 16bit DDR3 can also ok to connect
Jul 9, 2026 4:49 AM UTC
We are planning to use two 8-bit DDR3L memory devices, each with a capacity of 512MB.
Regards,
Shubham
Jul 12, 2026 2:01 PM UTC
how about using 1pcs 16bit ddr3 with 1GB/8Gb density? It should also fullfill the requirement and better cost than 2 ddr3
mƎALLEm
mƎALLEmBest answer
