MMarc.11
Mar 27, 2023 09:50 UTC
cube mx does not launch workspaces
Greetings,
in the video STM32MP1 workshop - 9 OpenSTLinux BSP pin Muxing - STM32CubeMX lab after modifying the DK2_TIMER_A7 project in the mx cube directly open the project in workbench from generate code, open the file.
On my pc this doesn't happen, this file opens:
<?xml version="1.0" encoding="UTF-8"?>
<workspace>
  <project>
   <path>$WS_DIR$\DK2_TIMER_A7.ewp</path>
  </project>
  <batchBuild />
</workspace>
And if I try to open the project directly from workbench I can't open it.
When I open workbench it tries to install GCC GNU COMPILER but fails
I attach some screenshots
Olivier GALLIEN
Olivier GALLIENBest answer
Mar 27, 2023 13:21 UTC
Hi @MMarc.11​ ,
Yes, apology for that. Some old video are kept online.
The Getting Started section in Wiki is a better reference always maintained.
https://wiki.st.com/stm32mpu/wiki/Getting_started
Hope it help
Olivier
Olivier GALLIEN
Mar 27, 2023 12:01 UTC
Hi @MMarc.11​ ,
Strange, I notice in one screenshot a path like /ac6/systemworkbench ...
Are you trying to use SW4STM32 ?
This is no more supported; you have to use STM32CubeIDE.
Olivier
MMarc.11
MMarc.11Author
Mar 27, 2023 12:21 UTC
I was trying to use workbench because it is used in an STMicroelectronics video (STM32MP1 workshop - 9 OpenSTLinux BSP pin Muxing - STM32CubeMX lab) which explains how to start using the STM32MP1.
Being a beginner with this micro I tried to follow the instructions of the turial step by step
Olivier GALLIEN
Hi @MMarc.11​ ,
Hope it help
Olivier
MMarc.11
MMarc.11Author
Mar 27, 2023 15:10 UTC
Thanks, I'll try to follow this path
