NP_it
Jun 7, 2023 07:24 UTC
Compilation breaking on custom machine
In the recently, for the past few days, I am facing this new issue that, if i compile for my custom som and program, i always get this error. But if I dont do any add-on of packages, I works fine.
I even added a simple package like "vim" using IMAGE_INSTALL in addons/conf/machine/<machine_name>.conf file .
I tried creating new directory and adding files and building from scratch multiple times. Still no success. It always crashes after resizing the partition.
Erwan SZYMANSKI
Jun 7, 2023 08:14 UTC
Hello @NP​ ,
As your crash happens only when you add you add-on on top of OpenSTLinux delivery, you have a good research scope to find your issue now.
Can you share me the modifications you do that cause the boot issue ?
Kind regards,
Erwan.
NP_it
NP_itAuthor
Jun 7, 2023 08:16 UTC
Thanks for the reply. As said, Even if i add a line as "IMAGE_INSTALL= " vim " " in my machine_name.conf . It doesnt work.
Also I see one warning in console. Pls find the pic.
Erwan SZYMANSKI
Jun 7, 2023 08:23 UTC
Are you sure you are not overwriting all the IMAGE_INSTALL with doing this ?
Can you try with a IMAGE_INSTALL += " vim \ " ?
Rgs,
Erwan.
