AApol.3
Mar 23, 2020 19:36 UTC
change OpenST Linux version in STM32CubeMX
We are using developBoard by Emcraft with STM32MP157A.
Emcraft release board with Openstlinux 4.14.
If I want change devicetree of STM32MP1 i need use STM32CubeMX to export new devicetree.
If i go in STM32CubeMX-->Project Manager-> Project OpenSTLinux setting, I CAN’T CHANGE version of STLinux.
Is it possible to change this setting?
Olivier GALLIEN
Olivier GALLIENBest answer
Oct 13, 2023 11:55 UTC
Hi @AApol.3 , @casparfriedrich ,
You have to use the version of CubeMX corresponding to your ecosystem.
Please refer to release note in wiki . eg for Kernel 5.15 it's ecosystem V4.1 STM32 MPU ecosystem release note - stm32mpu-ecosystem-v4
STM32CubeMX-v6.7.0 might be used.
openstlinux-20-02-19 correspond to ecosystem V1.0 ( deprecated and not recommanded !!) and require CubeMX5.6 for compatible manifests
Olivier
Olivier GALLIEN
Mar 25, 2020 14:29 UTC
Hi @AApol.3​
Kernel 4.14 is not supported by ST ecosystem but only by Emcraft.
I invite you to contact Emcraft for further support about tools and ecosystem addressing their SOM product.
BR,
Olivier
AApol.3
AApol.3Author
Mar 27, 2020 15:52 UTC
Hi Oliver,
Thanks for your answer.
we are contatting Emcraft, but if we want use STM32cubeMX to change devicestree of openstlinux-20-02-19, we can not change manifest or Linux version? If we want use old manifest or old Linux version, how we can change theese settings?
Best regards
Olivier GALLIEN
Olivier
Oct 13, 2023 11:16 UTC
I have exactly the same problem. I want to use the LTS-Version 5.15 but the "Manifest Version" says "openstlinux-6.1-yocto-mickledore-mp1-v23.06.21". My STM32CubeMX version is 6.9.2 on Linux/Windows and all software packages regarding STM32MP1 are installed.
Best regards
Caspar
