Mar 10, 2025 08:32 UTC
can I run only M4 core without A7 core, but not in debug mode? in stm32mp157
Currently, I'm running the M4 core by loading it through the A7 core.
Is there any way to make these two cores start independently, without interfering with each other, and only perform communication?
Olivier GALLIEN
Olivier GALLIENBest answer
Mar 10, 2025 08:42 UTC
Hi @csm ,
No, by construction STM32MP15 can operate only with the A7 Core as master.
M4 cannot start independently out of the Engineering mode limited to developpement purpose.
Can you elaborate further why you see this as a limitation for your product / use case ?
Olivier
Olivier GALLIEN
Hi @csm ,
Olivier
csmAuthor
Mar 10, 2025 08:54 UTC
In a product that needs to be developed now, it is necessary to ensure the stability of simple functions. I'm worried that after running linux for a long time, some issues will occur, leading to the entire device restarting.
