jh2
Jul 31, 2025 5:04 PM UTC
Boot issue with STM32MP257F
I am trying to boot an STM32MP257F with M33 master from SD-card (BOOT=0111).
I get the following error on PH4:
blockingfailure
S-0002031104084FFC
NS-0000000000000000
L-000000AE
What does it mean?
Best regards.
Erwan SZYMANSKI
Aug 1, 2025 12:51 PM UTC
Hello @jh2 ,
Can you precise if you are working with your own design or if you work on an Evaluation / Discovery kit ?
Kind regards,
Erwan.
jh2
jh2Author
Aug 4, 2025 10:33 AM UTC
Hi @Erwan SZYMANSKI ,
I am working on a custom design. In what sense is this information relevant in decoding the error message?
Best regards,
Erwan SZYMANSKI
Aug 4, 2025 11:22 AM UTC
Hello @jh2 ,
Very simply, to know if we could reproduce it on our side. Because if you had had this problem on an EV/DK kit, it would mean that we would have an issue on our side.
This log seems to be an error raised by the BootROM. I need to cross check with BootROM expert to know the signification, I will come back to you ASAP.
Did you try to boot in A35-TD and observed the same issue ?
Kind regards,
Erwan.
Erwan SZYMANSKI
Aug 4, 2025 11:30 AM UTC
According to BootROM expert, this log does not give the reason of the fail, it just indicates that:
  • The BootROM went to binary load step, but failed to complete it.
  • It may be:
    • A wrong header
    • A wrong memory place
    • A flash memory access issue
Kind regards,
Erwan.
