Boot error from SD Card on my original board
- 4 replies
- 1063 views
I want to boot my original board which STM32MP151CAA3 MPU is mounted on.
However, the following error occurs in the boot process and the process fail.
mmc0: error -22 whilst initialising SD card
I suspect that the description of User Code Section for sdmmc1(SD card) node in the device tree cause an error, but I have not known the cause of the error.
What could be the cause of the error?
I attach boot error log and original device tree sources.
Would you be able to lend your expertise.
Best regards.
H. Masuda
