HiroM
Nov 10, 2021 08:56 UTC
Android Build Fail - CONFIG_DEBUG_FS has incompatible.
Hi Community,
I am building android image of STM32MP157C-EV1.
I have got incompatible error when I have built as following commands.
commans:
  $ repo init -u https://github.com/STMicroelectronics/android-manifest -b refs/tags/st-android-11.0.0-2021-08-31 -m stm32mp1droid.xml
  $ repo sync
  $ source ./build/envsetup.sh
  $ lunch aosp_eval-user
  $ make -j
error:
  checkvintf E 11-10 15:16:51  206  206 check_vintf.cpp:554] files are incompatible: Runtime info and framework compatibility matrix are incompatible: No compatible kernel requirement found (kernel FCM version = 5).
  checkvintf E 11-10 15:16:51  206  206 check_vintf.cpp:554] For kernel requirements at matrix level 5, For config CONFIG_DEBUG_FS, value = y but required n
  checkvintf E 11-10 15:16:51  206  206 check_vintf.cpp:554] : Success
Obviously these files are mismatch.
  out/target/product/eval/system/etc/vintf/compatibility_matrix.5.xml
    1557:     <config>
    1558:       <key>CONFIG_DEBUG_FS</key>
    1559:       <value type="tristate">n</value>
    1560:     </config>
  out/target/product/eval/obj/PACKAGING/check_vintf_all_intermediates/kernel_configs.txt
    5548: CONFIG_DEBUG_FS=y
Which file should I change to fix this issue?
Or, is it better to fix it in another way?
As a side note, I have built successfully by chaning kernel_configs.txt.
Thanks & Regards,
Hiromichi,
Nicolas L
Nicolas LBest answer
Nov 22, 2021 08:30 UTC
Hi Hiromichi,
As mentioned in the wiki page https://wiki.st.com/stm32mpu-ecosystem-v2/wiki/How_to_build_STM32MPU_distribution_for_Android#Generating_the_image, it's required in case of user build to re-build the kernel. For that purpose, you have to execute the following commands in your build environment (after the lunch aosp_eval-user, but beore the make -j) :
$ load_kernel
$ build_kernel -i
Nicolas
Nicolas L
Hi Hiromichi,
$ load_kernel
$ build_kernel -i
Nicolas
HiroM
HiroMAuthor
Nov 22, 2021 08:57 UTC
Hi Nicolas,
Thank you very much for your kind instruction.
I'm sorry I didn't understand the wiki page properly.
I will try again according to your instruction.
Hiromichi
HiroM
HiroMAuthor
Nov 30, 2021 04:27 UTC
I have finished to build successfully.
I had to do the setup described on the following site for the kernel building.
https://wiki.st.com/stm32mpu-ecosystem-v2/wiki/PC_prerequisites
