jhi
Senior
Oct 17, 2022 12:01 PM UTC
USB not found
I have problem to get USB to work. I'm using custom board but I know that USB works because if I boot the board with the delivered image (MyIR) the USB works. I'm using buildroot with the 5.10 kernel and the linux kernel configuration from bootlin git.
In TF-A I have enabled CLK_USBPHY_HSE and CLK_USBO_USBPHY.
Kernel device tree:
&usbh_ehci {
	phys = <&usbphyc_port0>;
	phy-names = "usb";
	status = "okay";
&usbh_ohci {
	phy-names = "usb";
	status = "okay";
&usbotg_hs {
	compatible = "st,stm32mp15-hsotg", "snps,dwc2";
	phys = <&usbphyc_port1 0>;
	phy-names = "usb2-phy";
	dr_mode = "host";
	status = "okay";
&usbphyc {
	status = "okay";
&usbphyc_port0 {
	phy-supply = <&vdd_usb>;
	st,phy-tuning = <&usb_phy_tuning>;
&usbphyc_port1 {
Kernel bootlog (I enabled dwc2 debugging)
# dmesg | grep -i usb
[ 0.114896] usbcore: registered new interface driver usbfs
[ 0.114983] usbcore: registered new interface driver hub
[ 0.115069] usbcore: registered new device driver usb
[ 1.743100] usb33: supplied by vdd_usb
[ 1.791657] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.791754] usbcore: registered new interface driver pegasus
[ 1.791852] usbcore: registered new interface driver asix
[ 1.791915] usbcore: registered new interface driver ax88179_178a
[ 1.791976] usbcore: registered new interface driver cdc_ether
[ 1.792055] usbcore: registered new interface driver smsc75xx
[ 1.792133] usbcore: registered new interface driver smsc95xx
[ 1.792193] usbcore: registered new interface driver net1080
[ 1.792264] usbcore: registered new interface driver cdc_subset
[ 1.792325] usbcore: registered new interface driver zaurus
[ 1.792413] usbcore: registered new interface driver cdc_ncm
[ 1.793050] dwc2 49000000.usb-otg: mapped PA 49000000 to VA 7975fc9b
[ 1.793872] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.794375] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.795291] usbcore: registered new interface driver usb-storage
[ 1.807092] usbcore: registered new interface driver usbhid
[ 1.807108] usbhid: USB HID core driver
[ 1.866395] dwc2 49000000.usb-otg: mapped PA 49000000 to VA 3bad9e35
[ 3.243027] dwc2 49000000.usb-otg: mapped PA 49000000 to VA 474d4785
[ 3.376990] dwc2 49000000.usb-otg: mapped PA 49000000 to VA 13a1f023
[ 3.385604] dwc2 49000000.usb-otg: mapped PA 49000000 to VA 1c356f89
[ 3.462241] dwc2 49000000.usb-otg: mapped PA 49000000 to VA 46c345d1
[ 3.640278] dwc2 49000000.usb-otg: mapped PA 49000000 to VA cdf58676
An this is from the original image:
0.309427] USB33: supplied by regulator-dummy
[ 0.313788] usbcore: registered new interface driver usbfs
[ 0.313872] usbcore: registered new interface driver hub
[ 0.314020] usbcore: registered new device driver usb
[ 0.442943] stm32-usbphyc 5a006000.usbphyc: Linked as a consumer to regulator.5
[ 0.443071] stm32-usbphyc 5a006000.usbphyc: Linked as a consumer to regulator.6
[ 0.443197] stm32-usbphyc 5a006000.usbphyc: Linked as a consumer to regulator.3
[ 0.443805] stm32-usbphyc 5a006000.usbphyc: registered rev:1.0
[ 1.783244] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.790785] usbcore: registered new interface driver pegasus
[ 1.796362] usbcore: registered new interface driver asix
[ 1.801796] usbcore: registered new interface driver ax88179_178a
[ 1.807882] usbcore: registered new interface driver cdc_ether
[ 1.813689] usbcore: registered new interface driver smsc75xx
[ 1.819497] usbcore: registered new interface driver smsc95xx
[ 1.825172] usbcore: registered new interface driver net1080
[ 1.830875] usbcore: registered new interface driver cdc_subset
[ 1.836760] usbcore: registered new interface driver zaurus
[ 1.842426] usbcore: registered new interface driver cdc_ncm
[ 1.848662] dwc2 49000000.usb-otg: 49000000.usb-otg supply vusb_d not found, using dummy regulator
[ 1.857041] dwc2 49000000.usb-otg: Linked as a consumer to regulator.0
[ 1.863539] dwc2 49000000.usb-otg: 49000000.usb-otg supply vusb_a not found, using dummy regulator
[ 1.998801] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.009595] ehci-platform 5800d000.usbh-ehci: EHCI Host Controller
[ 2.015330] ehci-platform 5800d000.usbh-ehci: new USB bus registered, assigned bus number 1
[ 2.024135] ehci-platform 5800d000.usbh-ehci: irq 64, io mem 0x5800d000
[ 2.057519] ehci-platform 5800d000.usbh-ehci: USB 2.0 started, EHCI 1.00
[ 2.064088] hub 1-0:1.0: USB hub found
[ 2.071964] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.082427] ohci-platform 5800c000.usbh-ohci: Generic Platform OHCI controller
[ 2.089247] ohci-platform 5800c000.usbh-ohci: new USB bus registered, assigned bus number 2
[ 2.097907] ohci-platform 5800c000.usbh-ohci: irq 63, io mem 0x5800c000
[ 2.172746] hub 2-0:1.0: USB hub found
[ 2.180840] usbcore: registered new interface driver cdc_acm
[ 2.185045] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.193286] usbcore: registered new interface driver usb-storage
[ 2.199289] usbcore: registered new interface driver option
[ 2.204697] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.437543] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 2.501578] usbcore: registered new interface driver usbhid
[ 2.505770] usbhid: USB HID core driver
[ 2.641447] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 2.689908] scsi host0: usb-storage 1-1:1.0
[ 2.818748] dwc2 49000000.usb-otg: 49000000.usb-otg supply vusb_d not found, using dummy regulator
[ 2.826938] dwc2 49000000.usb-otg: 49000000.usb-otg supply vusb_a not found, using dummy regulator
[ 2.967633] dwc2 49000000.usb-otg: EPs: 9, dedicated fifos, 952 entries in SPRAM
[ 2.974629] dwc2 49000000.usb-otg: DWC OTG Controller
[ 2.978747] dwc2 49000000.usb-otg: new USB bus registered, assigned bus number 3
[ 2.986093] dwc2 49000000.usb-otg: irq 51, io mem 0x49000000
[ 2.993025] hub 3-0:1.0: USB hub found
[ 8.708645] usbcore: registered new interface driver uas
[ 18.015529] usb0: HOST MAC 60:0c:41:e6:65:40
[ 18.022923] usb0: MAC 8e:a1:99:df:67:b5
[ 18.025355] dwc2 49000000.usb-otg: bound driver configfs-gadget
[ 18.208866] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
I also tried with the original device tree configuration (this was for Kernel 4.19) which also didn't work with 5.10:
&i2c4 {
	pinctrl-names = "default", "sleep";
	pinctrl-0 = <&i2c4_pins_a>;
	pinctrl-1 = <&i2c4_pins_sleep_a>;
	i2c-scl-rising-time-ns = <185>;
	i2c-scl-falling-time-ns = <20>;
	clock-frequency = <400000>;
	status = "okay";
	/* spare dmas for other usage */
	/delete-property/dmas;
	/delete-property/dma-names;
	stusb1600@28 {
		compatible = "st,stusb1600";
		reg = <0x28>;
		interrupts = <3 IRQ_TYPE_EDGE_FALLING>;
		interrupt-parent = <&gpiog>;
		pinctrl-names = "default";
		pinctrl-0 = <&stusb1600_pins_a>;
		status = "okay";
		vdd-supply = <&vin>;
		connector {
			compatible = "usb-c-connector";
			label = "USB-C";
			power-role = "dual";
			power-opmode = "default";
			port {
				con_usbotg_hs_ep: endpoint {
					remote-endpoint = <&usbotg_hs_ep>;
/*usb host*/
&usbh_ehci {
	phy-names = "usb";
	status = "okay";
/*USB*/
&usbh_ohci {
 phy-names = "usb";
 status = "okay";
/*otg*/
&usbotg_hs {
	usb-role-switch;
	status = "okay";
	port {
			remote-endpoint = <&con_usbotg_hs_ep>;
&usbphyc {
	status = "okay";
&usbphyc_port0 {
&usbphyc_port1 {
But all I want is to get the USB-host work, so I don't really need the USB-C stuff. Any ideas what I'm doing wrong?
jhi
jhiBest answer
Senior
Oct 18, 2022 5:16 AM UTC
So got it finally working. I had to add pinctrl.
&usbotg_hs {
	pinctrl-0 = <&usbotg_fs_dp_dm_pins_a>;
	dr_mode = "host";
	status = "okay";
This isn't really done in any of the examples I have seen. Where is this usually done? Not even CubeMX adds this anywhere when I configure only USB host.
jhi
jhiAuthorBest answer
Senior
&usbotg_hs {
	dr_mode = "host";
	status = "okay";
