Ara.1
Aug 9, 2021 2:11 PM UTC
stm32mp1 sgtl5000 codec over i2s
Hi All,
i am getting kernel soc sgtl5000.c error
sgtl5000 0-000a: Error reading chip id -6
any idea where am i missing , let me know if you need any further inputs
&i2c1 {
   pinctrl-names = "default", "sleep";
   pinctrl-0 = <&i2c1__pins_a>;
   pinctrl-1 = <&i2c1_sleep_pins_a>;
   /*i2c-scl-rising-time-ns = <185>;
   i2c-scl-falling-time-ns = <20>;*/
   clock-frequency = <400000>;
   status = "okay";
   /delete-property/dmas;
   /delete-property/dma-names;
   sgtl5000: codec@0a {
      compatible = "fsl,sgtl5000";
      reg = <0x0a>;
      #sound-dai-cells = <0>;
      //clocks = <&clk_ext_audio_codec>;
      clocks = <&i2s1>;
       clock-names = "MCLK1";
      VDDA-supply = <&v3v3>;
      VDDIO-supply = <&v3v3>;
      sgtl5000_port: port {
         #address-cells = <1>;
         #size-cells = <0>;
         sgtl5000_tx_endpoint: endpoint@0 {
            reg = <0>;
            remote-endpoint = <&i2s1_tx_endpoint>;
         sgtl5000_rx_endpoint: endpoint@1 {
            reg = <1>;
            remote-endpoint = <&i2s1_rx_endpoint>;
&i2s1 {
   #clock-cells = <0>;
   clocks = <&rcc SPI1>, <&rcc SPI1_K>, <&rcc PLL3_Q>, <&rcc PLL3_R>;
   clock-names = "pclk", "i2sclk", "x8k", "x11k";
   pinctrl-names = "default";
   pinctrl-0 = <&i2s1_pins_mx &i2sa_pins_z>;
   status = "okay";
      i2s1_tx_port: port@0 {
         i2s1_tx_endpoint: endpoint {
            remote-endpoint = <&sgtl5000_tx_endpoint>;
            format = "i2s";
         mclk-fs = <256>;
      i2s1_rx_port: port@1 {
         i2s1_rx_endpoint: endpoint {
            remote-endpoint = <&sgtl5000_rx_endpoint>;
            format = "i2s";
         mclk-fs = <256>;
   sound{
       compatible = "audio-graph-card";
      routing =
         "MIC_IN", "Capture",
         "Capture", "Mic Bias",
         "Playback", "HP_OUT";
          dais = <&i2s1_tx_port &i2s1_rx_port>;
         status = "okay";
Olivier GALLIEN
Sep 1, 2021 9:14 AM UTC
Hi @Ara.1​ ,
You have posted several questions related to same problem.
We will gather all support under post : https://community.st.com/s/question/0D53W000010RjZfSAK/sgtl5000-codec-dsi-i2c
Olivier
Ara.1
Ara.1Author
Sep 1, 2021 10:33 AM UTC
Yes i had done this as i was not getting any response on this, query, i assumed to draft in detailed way so created a new quest,
